1st time changing oil ..
Did anyone have a hard time putting the oil filter cover back ON ?
My oil change was going well .. got it drained, put the Fumoto valve on and the filter off with. When putting the new filter / cover assembly back on, it kept trying to cross thread itself and for about 30 minutes would not keep itself straight. I was finally able to finesse with extreme slowmotion, and now I have some paranoid feelings about.
has this happened to you?
Is this thing supposed to screw on a bit then require the use of the socket to tighten down the rest of the way? I screwed it on, heard some squeaking ( I assume the rubber gasket seal making contact) and then just stopped - as if there were no more turning it can possibly go.
I let it be and everything seems fine. light went off immediately upon starting ..
did you make sure filter was "snapped" into the housing?
Look around 3:55 into the video to see what I'm talking about:
http://www.youtube.com/watch?v=ea5nk-AI6t0
Maybe I'll try grease next time, but why it would try to cross thread itself is beyond me considering the threads were pretty wide / coarse and not fine threaded.
Capt bj .. I have read through the seemingly never ending posts about oil change mishaps to include the common stuck oil filter cover, the over torqued oil filter cover, the wrong oil filter, the missing spring and plastic cage dilemma of the oil oil filter cover. i even watched the video posted above, but they didn't have the same issue I did - reason for this thread.
gary - yeah it was definitely trying to cross thread itself. one side would thread in, but my fingers would feel a gap on the other side. It did that no matter how square and how hard I pushed. I ended up getting it on with some finesse, but by no means a quick and easy task.
Late to the party, I also followed all the instructions, but so far for 3 oil changes I've done, 2 of 3 have wanted to cross thread, and yes, it took many tries to get it right. One time it went right on, no problems. I would be VERY wary of using a wrench for all but the last bit of tightening after the housing is firmly seated against the engine mount. If you can feel it binding up and that it's uneven around the gap, it is! Don't keep going!
https://www.northamericanmotoring.co...s-missing.html
getting the can back on can be a pain.
what works for me is to get the can in place and turn 'off' pressing down until I feel the threads click indicating they are lined up
then as I turn 'on' I press down HARD. You are fightling both the pressure against the filter and a spring so it takes some pressure down to get the darn thing to turn freely. After a turn or two you should begin to feel the rubber ring begin to engage and the can will sort of grab and slide . . keep turning I always end up needing to use the wrench to get the can down flush and never worry about the torque cuz it takes a good UGH just to get the can flush. Feel around the edge of the can and ensure you're down flush - and you'll also be checking for a booboo bit of o-ring sticking out but I've never borked one since I started the 'push down hard' method.
I still do oil changes for some others with GEN1's and have shown others this trick and it works for us . . . and we lube it too of course
Kimolaoha
07-05-2023 01:04 PM
silence2-38554
98
09-21-2016 02:52 PM
Colt45Magnus
08-12-2015 06:43 AM
