Suddenly VERY loud power steering motor
Alright, I've gotten used to the PS motor being loud over the past year. But suddenly this weekend, it got exceptionally loud. Much much louder than before. And when I turn off the car, the motor is still extremely loud while it is "winding down" for lack of a better term.
Has anyone else experienced this problem, and if so, have you had it diagnosed? I'm assuming this will be the umpteenth trip to the dealer for yet anothe problem.
Not to mention a new dash rattle and the driver's seat squeeks uncontrolably. YAY!
It's never happened to me, but I've heard other cars PS fans getting loud when the car's turned off. I've even heard of the fan starting up a minute or two AFTER the car was shut off. Some people on the Vegas trip suggested to check your oil level when this happens as it could be indicative of low oil.
Yeah - just had that same problem. Took it to the dealer and discovered that the power steering fluid was completely gone - it had leaked out through a connection near the wheel and filled the CV boot with brake fluid. All was fixed by the dealer in a couple of days. They replaced the boot, line, and missing fluid (which I am told is a VERY expensive variant). the only thing I noticed besides the whine was slightly heavier steering.
You can check the fluid level easily.
I'm with MINI USA. If you haven't already been to your dealership or spoken to your service advisor about this problem, you really should. We'd be happy to contact your dealer for you if you'd like. Just give us a call at 866 ASK.MINI and mention Reference # 200406200550 so that we can help you more efficiently.
MD,
Is this a general problem or one that has generated a recall of any kind? I would assume not, but, when you gave Storer the ref.#, I thought I better ask. Thanks!
MD,
(Not So) Power Steering
Where do you check the PS fuild levels? There is nothing in the manual about it. Also I don't see anything about the spec of fluid to put in there if is has leaked out. Does anyone know what the standard spec is for the fluid in the PS system?
The power steering reservoir is to the right of the coolant tank, behind the engine, when viewed from standing in front of the car. The reservoir has a black, star-shaped cap. As for fluid type, it's most likely standard hydraulic power steering fluid. If your reservoir is near empty, I'd take the car to the dealer and have them check where the fluid went. If it disappears with no visible signs under the car, then in many cases it's leaked into one or both of the steering rack boots. This is a problem not limited just to MINIs.
Thanks for the quick reply Greatbear. I took a look under the hood and this looks like the reservoir from your comments.
</SPAN>
And I opened up the cap and sure enough it is bone dry.
Looks like a trip to Autozone to tie me over until the dealer can get to it at the end of next week. There have been no drips underneath, so I guess the fluid has drained to the rack boot cover.
Thanks again for the advice.
</SPAN>
It's sort of strange that the MINI owner's manual overlooks the power steering fluid reservoir in the owner checks. It's not difficult, does not require tools, etc. Simply unscrew the cap and read the dipstick inside as well as look into the reservoir itself.
After I had posted this I checked it out on my car, and indeed the fluid recommendation was given on the cap, plus the fluid has a bit different smell and lighter consistency than standard universal power steering fluid. Good that you got the required fluid and put it in during your wait for service. You'd be saving the pump and related items from damage.
Manny_cooper
09-10-2015 11:09 AM
JPMontes3
08-23-2015 01:26 AM
minipopkart
08-13-2015 05:22 AM
