Valve noise when cold.
Are the R56's (turbo in my case) known for valve chatter when they're cold? It's not really loud and definitely not a death rattle, but coming from the world of modern pushrod V8's I'm not used to hearing valve noise. It pretty much stops once warmed up, but it's definitely there when cold. Could it be attributed to simply being a DOHC with a plastic valve cover? Currently just shy of 7500 miles and will be getting the first oil change done at the dealer in the coming weeks if that makes a difference.
MINIs are noisy at idle especially when cold. It took some getting used to for me as well. More so with my old justa Cooper than the new JCW as the exhaust does a good job of masking it.
I walk by some peoples cars and they are so quite when idling!
Post of vid of the noises on youtube if you want some feedback from NAM to help figure out if it is normal or not.
It took some getting use to the noisy engine for me too. I came from the US V8 truck world where those engines purr quiet. Now I have had my R56 for a while I can tell when it's down on oil from the change in engine/valve rattle. Still wish the engine was quieter tho. On Honda you can barely tell when it's running it's so quiet.
Supertractor3
04-07-2017 11:16 AM
09-02-2015 09:05 AM
