Just threw code P2885, charging press control min?
Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Clubman (R55), Cooper and Cooper S(R56), and Cabrio (R57).
I removed the oxygen sensor and could see the wastegate move. Next I think I will pull the heat shield and check measurements for the actuator rod, if I can find them.
I found my problem and stated the solution in a thread 2885 solved. The solution was the wastegate linkage going through the exhaust housing had developed a lot of play. I solved it by replacing the housing.
Czar had posted the correct actuator rod movement.
