Oxigen Sensor removal
Vendor
YES you should use Anti-seize on the threads, just a little so you can get it out later if you need to take the exhaust off. Most 02 sensors actually come with a little anti-seize already on the threads and have a plastic protector over them. The important thing is to not get it on the tip.
A crescent (adjustable) wrench? No no no no no! The adjustable wrenches are not secure, their jaws will open up and they'll just round the bolt head. At least, on any bolt that is corroded or stuck at all.
There's a reason that the O2 sensor sockets go almost all the way around the sensor. That is much more secure, and allows you to put more torque into the bolt head.
Crescent wrenches are OK for home repair projects, but you shouldn't be using them on a car IMHO.
Kimolaoha
07-05-2023 01:04 PM
Drivetrain Help on MAF Sensor Clip - Cannot Remove
Motown
04-20-2018 09:31 AM
squawSkiBum
10-02-2015 09:21 AM
DWooderson
08-10-2015 09:12 AM
