Tips for using Mini Roadside Assistance?
So I have a 2010 Clubman with 33k miles that has a check engine light on (wires to sensors broken as detailed in another thread).
The car is under warranty, so I'd like the dealer to take care of it BUT I'm 230+ miles from the closest Mini dealer.
Will Roadside Assistance tow it there (and back!) for me?
Is there a cost?
Anything I should say or do to make sure they do it for free/under warranty?
Any tips for making sure this works out?
thanks
-James
Is there a cost?
thanks
-James
I think you should be covered for a tow if the CEL is one of those which tells you to call the dealer (as opposed to the yellow ones that tell you to continue but to call for a service asap). I'm not sure what the fine print is for roadside assistance, but my impression is that it is a 24 hour/anywhere deal. Maybe you should just call them and find out?
However, I'm pretty sure they won't bring your car back. You'll have to retrieve your vehicle after the repair has been completed. If your situation is one that qualifies for roadside assistance, then, no, there will not be a charge for the tow. But there might be a charge for the repair if it's not something covered under warranty.
Your best bet really is to call them and ask these questions.
Thanks for the info-- particularly the difference between the various light meanings.
Just to clarify, I definitely plan on calling and asking these things (and I'll even post a reply to this thread to let others know how it goes). I also didn't want to say the wrong thing/frame the issue wrong and have them say "nope you're out of luck" IF there was a way I could ask that would be more likely to give the answer I want!
For what it's worth, when my CEL came on and the car started hesitating/surging randomly, I called roadside assistance and told them just that. They picked it up with zero hassle and took it up to my dealer (about 180 miles away), and the dealer called and arranged to have them bring it back to me with no issues either. They're pretty lenient, just tell them the car isn't running right.
I'll agree. I had my car towed about 20 miles when I had a flat. I didn't have a plug kit at the time. The lady at the 1-800 # tried to get me to drive on the run flats but I didn't want to ruin the tires (as you will once it is at 0 PSI). So they sent a flatbed within 40 minutes and I dropped the car off at the dealer after 7 when they closed. I went home and got my plug kit and plugged and brought my own air tank. Turns out my dealership has a hose reel int he service drive that has air and water available 24/7 so I stop by there instead of getting the compressor out and getting it pumped up, etc.
I will also be calling MINI Roadside Assistance tomorrow AM, Molly is having to be flatbedded to MINI of Portland for NO Coolant in the Resevoir. Have already contacted my SA Jarid and let him know what was going on. This happened tonight so I was very happy I was able to get a hold of him and he got back to me so quickly, within a min....seriously!!
I've got a great SA!!
Update...
I took 17pics. of various stages of my Baby being loaded up and hauled away!!
Well, step one is complete: Mini Roadside Assistance sent a flatbed from a local towing company out to pick up the Clubman (named 'Hilda' cuz it kinda reminds me of a hippo - sometimes lengthened to Hildegard cuz it's German).
The guy that picked it up was really friendly and said he routinely transports Minis, BMWs, Land Rovers and Jags for warranty work since there are no local dealers (all more then 100 miles away).
Wish I'd washed her first, but oh well....
I'll update more when I she comes back....
and just to finish off the saga-- the car was delivered back to my house by flatbed at about 8pm last night. The repair to the wiring was made, and they did an oil change (under the wear warranty) a bit early, since I live so far from the dealership. It also looks like they washed the car!
So to summarize:
car had problems including some drivability issues
I called Mini Roadside Assistance Monday AM
They sent a flatbed to get the car Monday AM
I called dealer service center to let them know car was on the way and what the problems were
Service Manager called once car arrived and they figured out problem (late Monday)
Work performed Tuesday
Service Manager called Tuesday afternoon to make sure I'd be home Tuesday night, then ordered up a delivery (via flatbed) under the "Mini Reunite" service, since I live more than 100 miles away (230miles!)
Car arrived Tuesday night.
Great Service from Mini and from Peabody Mini!
So to summarize:
MINI has two apps for the iPhone. Don't believe it is available for Droids -if it is I am sure someone will jump in.
Mini Roadside Assistance App - which can track service, your vehicles, and get roadside assistance for you.
Mini Link App - which allows you to interact with other Mini owners who use the app. Allows for virtual waves, marking twisty roads, points of interest and more.
Both are in the app store.
07-16-2020 12:54 PM
Drivetrain Help on MAF Sensor Clip - Cannot Remove
Motown
04-20-2018 09:31 AM
08-10-2015 02:03 PM
08-10-2015 01:59 PM
