Knocking Noise possibly front left - Any Ideas?
I've had this a while and cannot get booked in at the chap I would prefer who does track cars and is very thorough.
Mini could not find anything when it was in for the water pump recall but as I tend to do most things myself I think my local dealer is only happy to do recall and TLC work and no longer goes the extra mile on my car.
So just wondering if anyone else has experienced such noises. It has got worse on the drive home tonight.
I have had wheels off for cleaning and could not see anything suspect.
Running Bilstein PSS10 coilovers with adjustable top mounts and M7 J Brace if that helps???? 56 plate R56 with 55k miles on it.
I believe wheel bearings need replacing at some point so this may be a culprit at my mileage but not sure if a worn one would cause knocking. Thinking more balljoing or the bushing at rear of wishbone which I can imagine knocking when worn.
If anyone has any ideas what it could be I would appreciate it.
It is like a knocking noise most noticeable at slow speed, on uneven road or when doing a manouvre like a 3 point turn.
It is like something has slackened off causing play and a knocking noise is how I would best describe it.
After 5.5 years and 55k miles it could be bearings, ball joint, bushes etc. I would have thought wheel bearings would be more of a hum noise than knocking but never experienced a worn one.
07-16-2020 12:54 PM
silence2-38554
11-12-2015 09:39 AM
iamcamkeenan
08-10-2015 03:31 PM
