Just-a-Cooper Oil Consumption
After my oil light came on in hard corner, I added a full 2 quarts to bring it back up to near-maximum, but I am concerned that it lost 1.5-2 quarts in six thousand miles. I've never had to add oil prior to this, and I still don't see spots on the garage floor or a smoke trail. Any ideas? I've heard about excessive consumption in Cooper S's, but I haven't found any reports of loss in the NA Coopers. My car only has 42k miles on it, and has been driven relatively conservatively since I bought it at 13k miles. I'll be checking the oil daily from now on to see if I can detect any loss over the next week.
Thanks for your help.
A qt every 3K miles is probably a little higher than average, but it is well within the normal and acceptable range. You might be surprised to know that Mini considers a quart every thousand to be acceptable on a brand new car. Oil consumption varies quite a bit from car to car and unless it is really high, is not typically a cause for concern. It is a nuisance to have to add it, but you pays your money and takes your chances.
You need to check your oil more often.
- Mark
- Mark
If it just suddenly started using oil and you don't have a leak it could be a bad PVC valve which in these cars is part of the valve cover. On most cars you have little PVC valve somewhere that only costs about $5 to replace, in the Mini, not so cheap or easy but might take care of your oil consumption...
molala
10-02-2015 01:53 PM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
09-10-2015 12:34 PM
09-03-2015 03:01 PM
09-02-2015 09:05 AM
