Clutch slave replacement
Old 11-13-2012 | 12:17 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Originally Posted by MiniMacster
I can see the logic in that. What I am concerned about is the outlet of the master cylinder is lower than the inlet. That makes me think that air is trapped in the master cylinder near the inlet. I nave never figured out how to get air bubbles to go down myself.
Just a small side note, have you driven the car at all? If so, any improvement with the clutch engagement point?
I think you answered this already as well, but the piston in the slave cylinder was pushed in, right? - if not, it won't bleed properly (as you know).
Also, consider gravity-bleeding as Cristo mentioned, we've read that helps removing the trapped air in the master cylinder which is what this sounds like.
888.280.7799 | 6am - 5pm PST
  #27
Old 11-13-2012 | 01:22 PM
MiniMacster's Avatar
MiniMacster
There is not appreciable improvement. The pedal feel is weak at the top. I may try the gravity bleed to see if there is an improvement. As it is now when I shift I can feel the syncros catching like the clutch is not fully disengaged. If I get it bleed well, and still feel the syncros I may have to look into it more to see why. And yes, I did compress the slave cylincer for bleeding. It makes sense looking at it that if it were not you would have an air trap built into the slave cylinder.
  #28
Old 11-13-2012 | 02:00 PM
cristo's Avatar
cristo
Alliance Member
This video may help - a little generic and schematic, but gets the idea across.
Finhead
105
08-14-2023 07:51 AM
eliseo1981
01-28-2021 02:45 PM
PrimePower
08-16-2015 06:29 PM
Powershift
08-16-2015 05:14 PM
Colt45Magnus
08-12-2015 06:43 AM
Quick Reply: Clutch slave replacement
