New Window Motor runs backward???
Old 05-17-2012 | 01:51 PM
movieman's Avatar
movieman
So, I just installed a new window motor and it runs backward...up is down and down is up. Why/how do I fix this?
Old 05-17-2012 | 01:58 PM
MSFITOY's Avatar
MSFITOY
reverse the polarity?
Old 05-17-2012 | 02:06 PM
movieman's Avatar
movieman
how?
I can't figure out how to get the wiring connector apart.
Old 10-05-2013 | 04:16 PM
McNut's Avatar
McNut
Props to "Paul P" for posting the solution on youtube.
1. Take the regulator assembly out of the door. :( You can just take out the front part with the motor on it if you're lazy.
2. The metal motor housing is secured to the plastic gear box with 4 small screws at the base of the housing. Remove them.
3. Slide the housing about half way off the motor, rotate the housing around the motor's axle 180 degrees, and slide it back on.
4. Reinstall the 4 screws.
5. Reinstall the regulator assembly in the door.
Voila!
07-16-2020 01:54 PM
surfblue
10-24-2018 02:20 AM
Gil-galad
Eastern Iowa MINIs
63
11-17-2016 03:54 PM
12-23-2015 11:36 AM
minimaximum
R55 :: Clubman Talk (2008+)
08-14-2015 05:05 PM
