Starting issue
Starting issue
Hi, I have a problem with my 2002 MCS w/ 60K miles. Here's the load down:![Sly](https://www.northamericanmotoring.com/forums/images/smilies/sly.gif)
1. MSC started fine in the morning and ran normal.
2. Helped a friend to jump start a dead battery in his Toyota (connected jumpers from the rear battery terminal).
3. power down MCS and started it up again to head out to our local Sears to buy his replacement battery (it's less than 5 miles away).
4. Had lunch for about an hour.
5. Started the MCS and it wont turn. I can hear it is trying but wont turn as if there was not enough gas to start.
6. Did a "rolling start" and all it made was a fluttering sound. did not start.
7. checked my "Red Top" battery for defects and there was none. It's two years old. My Stewart volt gauge shows that the power was around 10 vs 12 (i think that is where it is normally).
8. placed a good battery into my MCS and still wont start (same result).
9. I even reset the inertia kill switch located near the upper right in the engine bay and had no luck.
Here is what I'm wondering:
1. It is a fuel issue. Could the jump cause the fuel relay or some electrical to blow?![Mad](https://www.northamericanmotoring.com/forums/images/smilies/mad.gif)
2. Could the Clifford Alarm Matrix alarm I have could have trigger the fuel cut off?![Mad](https://www.northamericanmotoring.com/forums/images/smilies/mad.gif)
3. Could it be a simple Battery low issue?![EEK!](https://www.northamericanmotoring.com/forums/images/smilies/eek.gif)
Got my MCS back into my garage now. Need to see what is wrong or I need this to be towed to the mechanic.![No](https://www.northamericanmotoring.com/forums/images/smilies/no.gif)
Thanks everyone in advance.
![Cry](https://www.northamericanmotoring.com/forums/images/smilies/cry.gif)
If there might be a short, I wonder if my Fuel pump relay might have been blown? I found out our local Oreilly has it for $23 bucks.
Still not moving.. =(
So I replaced the battery, barrow a working relay. MCS is trying to turn but sounds like there is no fuel. I even reset the inertia kill switch (the mystery button for the 02 MCS), and still does not work. Unless there is another relay, I give up. Called my mechanic and tow for next week.![Mad](https://www.northamericanmotoring.com/forums/images/smilies/mad.gif)
Car was towed into my regular MCS mechanic. It should be resolved by today. It was a dead fuel pump and much needed replacement fuel filter. You figure with premium gas, the filter should be pretty clean. They said that for a MSC pump to run 10 yrs was pretty good. Thank goodness it was just that. But my bill will be about $900.
09R56
11-16-2022 10:49 AM
tippin
08-05-2015 08:43 AM
