Oil pressure related noise; lifter or rod
on
I have an oil pressure dependant noise that at startup,
Oil pressure cold is always 75+lbs
Hot at idle is 17-20 lbs
Hot at 3200 rpm = 50lbs
39000 miles
2006 gen1 JCW
The only thing that has changed recently is I used 0-30 Mobil 1 European formula, but the noise has only become noticeable the past couple weeks. Before that it was whatever the stealer had put in it. I bought it at 29000 miles in December.
Since it is so short in duration, and dependant on a long wait in between "tests" what should I look for to assess if its rod knock or lifter related?
-Scott
- Goes away when the idiot light goes out
- Is longer in length and more often the longer the car sits
- But isn't there 100 percent of The time
- Slight rattle but not a loud bang
- Never comes back, no matter how hot or how long the car runs
39000 miles
2006 gen1 JCW
-Scott
07-16-2020 12:54 PM
