Motor Mount Help!
Motor Mount Help!
So I'm replacing all of my motor mounts. I got to the passenger side front mount after following these directions:
http://www.pelicanparts.com/techarti...eplacement.htm
I couldn't find the torx bolt on the bottom of the frame, so I started to wonder if the mount had previously been replaced and the bolt wasn't torqued properly and fell out. So I pulled from the top and noticed that it was threaded in. Now I have this:
![](http://www.cincykarting.com/wp-content/uploads/2012/07/motormount.jpg)
The new part has a threaded hole looking for the non-existant torx bolt. My frame is threaded all the way through. I can't find a part # on real oem that shows the mount I just removed. Any ideas?
Vendor
That means you have a REALLY early 02 MINI, only ever seen 2 of these. You can't get the screw in mount. The mount you have is the only OEM replacement available. So you have to get a very large drill bit and drill out the threads in the rail and also get a new torx bolt and install it like the later 02 cars had. It works fine I did it on both the ones I ran across. I've got the torx bolts in stock if you need.
Way, you definitely know your stuff. Mine's an 02/02. And Mini here in Cincinnati confirmed I can't get that part. They put that torx bolt on order for me. Should be here Tuesday. You don't happen to be in Cincinnati where I could come pick it up? Hahaha. Anyways, I found an M10x100 at Lowes. Probably too short but I'm gonna go check it out. I don't want to drill the threads until I'm sure I have a bolt that's going to work though...
JPMontes3
08-23-2015 01:26 AM
minipopkart
08-13-2015 05:22 AM
