06 Airbag Light - How much $$$??
#26
Sp4rtan, Great pic of what the thing looks like. I assume you removed the seat and cover to get a look see at what was under there? Now I understand why they are asking for $1,200 to replace, lol. Anyone know if you can buy the unit and replace it yourself. It doesnt look that hard once you get the seat out. Just some time.
#27
Actually, I had the cover off because I was replacing it with leather and adding seat heaters at the same time. Having been there once, I imagine that if you gave me a replacement sensor element I could probably swap it out in a couple of hours. I guess I can see why MINI doesn't want us poking around in there - the liability could be pretty severe if anything were to go wrong, but it should be a lot cheaper fix.
#28
-2 year warranty on parts/labor (this SOB might just break again…)
-Reimbursement if a future recall is ordered (MINI confirmed they give $$ back)
-Peace of mind that it was done correctly..
-New seat bottom isn't much more than the sensor alone. Might as well..
#29
I don't want to be a douchebag, but I'm curious if I should try and get half the $1,000-1,200 from the seller of the car I bought 2 weeks ago. Seems fair to me. If it was 6 months and the sensor broke… hell, even 1 month. But I found out 2-3 days later - Really pisses me off.. What do you guys think? Its some med-student with presumably well-off parents - not that it matters, but makes me feel less douchey.
#31
#32
#33
I wonder if it might be the seat belt latch instead. My wife and I both have '06s. Both were bought used a little over 2 years ago. I think that mine may have an earlier manufacture date. Anyway, mine had the light show up shortly after we got it. It was random at first, but has been a constant reminder since then. The light in her car started showing up randomly about 4 or 5 months ago. It would go out if the seat belt latch was wiggled a little. Also, if the light is on in either car, and the seat belt is not latched, the seat belt light does not come on.
Basically, I'm wondering if a wire in the latch might be grounding out, causing the car to not see that the seat belt is buckled or not.
I thought about checking the wires, or getting another, but since it has "explosives" in it, you can't order one online. Basically, the "explosive" pre-tensions the seatbelt upon the event of a crash.
Just my thoughts. I'm not really worried about the light, it's just annoying.
#34
My airbag light activated on the dash last week, p/s seat pad was already replaced twice under warranty
There is a TSB out for it
http://www.aboutautomobile.com/TSB/2.../Cooper/Airbag
And a list of complaints without a resolution.
http://www.aboutautomobile.com/Compl.../Cooper/Airbag
I'll just wear a helmet from now
#35
I had the light(s) go on dash and overhead for several months after I loaded the seat on a trip with inanimate objects. I recently set a rather heavy computer bag on the seat for several trips and suddenly the light has now stayed off, even when nothing is on the seat. I would try something like that to see if some level of seat loading will reset the faulty part prior to buying. Somentimes it's good to be lucky.
07-16-2020 12:54 PM
trw92a
08-26-2015 01:47 PM
quality_sound
08-07-2015 09:36 AM
