Power steering stays on, kinda made a workaround
Okay so I bought a power steering pump from someone on here about a year ago and just got around to installing it. The guy I bought it from told me it was in 100% working condition with only 33k on it. Think I paid about $170 for it. Well, after installing it, as soon as I plugged up the power it turned on. Even with the ignition on/off plug in it still stays on. So I'm thinking I got sold a bad pump or there is a short in my system somewhere telling it to stay on all the time. But my old pump worked only when the car wasn't hot and it never stayed on with the car off.
Well, what I ended up doing was going from the hot to the FL4 100amp fuse, then to a simple toggle on/off switch, then back to the other end of the power source. Now I have the ability to manually turn it on and off at my pleasure which is kinda convenient.
I am curious if there is a power source in which is only on when the engine is running that I can wire to the switch as a "remote" to tell it to turn on when the engine is on. Then I can turn it off if I want. But for now this works and I at least have power steering when I need it haha, and I can turn it off when I hit up the track!
The electronics on the pump are going nuts! (you probably already know that).. But anyway, same thing is happening to my car and I've been disconnecting my battery from inside of the car since my stupid boot decided to jam itself shut.. I bought a brand new OEM pump and fan for $360, I did think about doing something like you're saying but I'm just going throw it out and put the new one in..
As far as a relay goes any kind you reccomend as far as size or could you run a switch to tap into the two wires an simply use an inline fuse?
"Well, what I ended up doing was going from the hot to the FL4 100amp fuse, then to a simple toggle on/off switch, then back to the other end of the power source. Now I have the ability to manually turn it on and off at my pleasure which is kinda convenient."
Hi, I ran into the same problem and am wondering what steps or parts you used to come up with a toggle switch.
Just remember, it is not a perfect fix...
the pump runs on 2 speeds.....the reason for the electronics, and you are just cutting the power....
Early on a few MINI'S DID BURN due to ps pump issues, so i urge you just to use this rigged fix as a very temporary fix till you can save up the $$ to fix it right.....
Etrain
16
08-05-2024 05:37 AM
JPMontes3
08-23-2015 02:26 AM
minipopkart
08-13-2015 06:22 AM
