Replaced Power Steering Pump - Not working
Hey everyone,
I just finished putting in a new power steering pump that my friend got from the Mini dealer over here.
Everything is connected, fluid is in, yet the pump still doesn't function.
It is an '03 MCS with a little over 100K miles on it.
I've tried disconnecting the battery again, then disconnecting the pump and letting everything sit for bit, then connecting everything back up. Still no dice.
Not sure where to go from here. Checked the fuses I could get to. DOA pump maybe? Or am I just missing something else?
If the 100 amp fuse is blown you will not get power down there. Good news is if you blew the 100 amp fuse, you still needed a pump.
Your are testing with a test light? You need to fully test both sides of each fuse.
Chad
Detroit Tuned
Chad
Detroit Tuned
07-16-2020 12:54 PM
bc219
08-10-2015 11:22 AM
nismo4life
08-05-2015 08:31 AM
