Fuel gauge on empty - tried everything to fix - ti signal implausible (no reading)
Hi NAM members,
My mother has a 2003 Mini Cooper S. The gas gauge on her car is always at empty with the red bar illuminated under her nav screen. Also the range is ---.
After searching this forum and reading about the issue, I changed both the fuel pumps with tested working used ones.
The gas gauge still doesn't work properly.
After further research, I also entered the hidden menu in the OBC and came up with the following:
In test #6.2, the display reads 3
For reference the values indicate:
Test 6.2 Shows value of Fuel gauge. 1= both senders OK, 2= sender failure, 3=ti signal implausible (no reading)
I have number 3 which means ti signal implausible (no reading) showing on the OBC.
Also after reading the mini specific obc codes in the OBC via test #14, the numbers I get are 11422 on test 1 and the other tests are 00000 (indicating one code)
Can anyone please assist me in troubleshooting this issue?
I tried to research the issue to the best of ability but I am still out of luck.
Thank you kindly in advance for any help.
07-16-2020 12:54 PM
