Shaking R53 around 45+ mph and when going uphill
Old 08-31-2012 | 08:48 PM
marantz2010's Avatar
marantz2010
Hi all,
I've got an R53 JCW w/ 88,000 miles and shakes (vertical motion) badly when going uphill from 45 mph and up. Does not shake noticably when going downhill. Will shake on a level surface if I stomp on the gas at these speeds. Seems to get worse when RPM's get higher--gets very bad at 3,500+ RPM's. I've done my research and have investigated this for a couple weeks and have already done the following:
- Clutch is not slipping nor making noises. Clutch pedal does not shake.
- Replaced front control arm bushings (which needed to be replaced anyways)
- Replaced spark plugs
- Replaced fuel filter
- Replaced air filter
- Inspected ignition coil terminals for corrosion. No rust to be found.
- Inspected spark plug wires and are in good condition.
- Front shocks should be replaced--a little "boat-like."
- No clicking sounds when turning so it's not the CV Joints.
At this point, I'm at a loss and this is a last attempt of self-diagnosis before going to the dealer. Any ideas?
Thanks in advance!
Old 01-12-2014 | 01:52 AM
marantz2010
I struggled with these vibrations for over a year. It was time for a new clutch at 106k miles this week. I replaced the clutch with a Valeo single-mass flywheel kit from Waymotorworks.com and the vibrations have gone away completely.
Advice for anybody with vibrations like I posted previously: don't underestimate how much a clutch has impact on a vehicle. I thought I knew what slipping of the clutch was, and turns out I was wrong. [I did replace quite a few parts trying to solve the problem, which was overkill, but they needed to be replaced with the kind of mileage I have anyhow]
Send me a private message if any of you have any questions--or post a response on this thread.
Old 01-12-2014 | 02:09 AM
Fir3Chi3f's Avatar
Fir3Chi3f
Since there is no like button on this site, let me just say thank you! I have not had this problem (yet) but like to read a little bit of other's experiences for the future.
Old 01-12-2014 | 02:16 AM
marantz2010
One of my biggest pet peeves is having an issue with my car, going online to read about others having the same issues, and then not finding a solution despite an entire thread about about the issues. I just wanted to tie ends on this thread and state what the solution ended up being.
Old 01-12-2014 | 03:45 PM
minsanity's Avatar
minsanity
Check your engine & tranny mounts.
mellocooper
R55 :: Clubman Talk (2008+)
07-21-2016 06:05 PM
Gabe3
Tires, Wheels, & Brakes
16
04-16-2016 08:55 AM
David.R53
09-01-2015 07:49 PM
Jacob Kenney
09-01-2015 11:22 AM
xpunisherx
08-10-2015 11:50 PM
