How do I get the clips back on?
Old 09-08-2012, 05:35 PM
scatpack's Avatar
scatpack
scatpack is offline
What's the secret? The clips that keep the air hoses on... Easy to get off.... Hard to get on!
What's the secret?
Old 09-08-2012, 07:52 PM
kapps's Avatar
kapps
kapps is offline
Intake hoses? Grab some pliers (not needle nose) and a small-ish flathead screwdriver. Put the blade of the screwdriver under the clip part and use the pliers to squeeze the clip together. Once it's over, slide the screwdriver out. Use the flat end of the pliers, not the side.
Old 09-08-2012, 08:57 PM
Eric_Rowland's Avatar
Eric_Rowland
Eric_Rowland is offline
Ideally, use a set of ignition pliers - they look like a channel-lock, but are smaller (you can find them at Sears.) Full size work too, but the smaller ones make it easy. Put the top on the 'over' side, and the bottom on the 'under' side. Still takes some practice, but it works.
Old 09-08-2012, 09:28 PM
gerry2153's Avatar
gerry2153
gerry2153 is offline
I took the easy way.... I bought some regular ones
Old 09-08-2012, 10:31 PM
Sp4rtan's Avatar
Sp4rtan
Sp4rtan is offline
The best tool I've found is a set of wire strippers - the kind with the thin flat cutting jaws at the end. Mine are Belden, but there are lots of no-name versions. Totally effortless.
Old 09-09-2012, 05:35 AM
Capt_bj's Avatar
Capt_bj
Capt_bj is offline
ditto
or - if we're talking the big hoses for the air intake - there's no pressure to speak of on these lines and a long 'zip tie' works just fine. That's what some CAI kits come with.
surfblue
10-24-2018 01:20 AM
Motown
04-20-2018 09:31 AM
eastport_mini
General Mini related Ads
03-28-2016 08:35 PM
absolutcamper
08-24-2015 12:27 PM
Quick Reply: How do I get the clips back on?
