Anyone Use "Radiator Flush" When Changing the Coolant?
My coolant system wasn't well maintained until about two years ago when I replaced the coolant. It had been way too long when I did that switch!
I've done a few other repairs here and there over the last 2 years that have required me to remove a coolant hose or two and I always notice the build-up of deposits on the inside of the coolant hoses. It's always made me a little uneasy, but I've never had any overheating issues, so cooling ability doesn't seem to be affected.
Nevertheless, I've been thinking about using a "radiator flush" solution next time I change the coolant. Something like this:
Have any of you used these on your MINI? Is it worth it, or could it possibly do damage to the system?
Any thoughts are much appreciated!
Hi there:
Speaking of coolant flush/change, my 06 is up for coolant change again after 2 years. I am always concerned for the hoses and had asked an BMW/MINI shop to change them. The shop manager last told me it was way too soon to change mine. At this point I have 22000miles on after almost 7 years. Giving the heat generated by the S/C and the confined space under the bonnet, I would not think the hoses should be left unchanged for yet another 2 years.
What's your take? TIA.
Hi there:
I suggest just taking a look at the hoses just to be sure. If something doesn't seem ideal, maybe just replace that one. My heater hoses were really messy from a power steering fluid leak I had, so it made sense to replace them. The updated hoses from MINI I installed also had more thermal protection too. Since mine is an '03, my guess is they figured out a few things and improved the design for the later years like yours.
on
I used a Peak flush at the beginning of summer. They say to leave it in for six hours of driving time. Due to scheduling, I exceeded that by a wide margin. My radiator failed a few months later. I'd say make certain the flush is compatible with these fragile aluminum radiators, and then follow directions closely.
Nevertheless, it's a story like that that makes me hesitant to use the stuff at all since I'm not having any overheating issues even though I know the system is not all that clean...
on
I agree that it could be coincidence. I also wish I was more careful about following the directions. The reason for my extended install of flush was simply waiting for a new thermostat to arrive (bad gasket) and not wanting to deal with the bleeding more than necessary. I put the flush in after doing the head, and didn't have the thermostat gasket on hand at the time, when I broke it on removal.
Kimolaoha
07-05-2023 01:04 PM
