Sunroof problems
on
Sunroof problems
Sunroof has been making noise (creaking, popping) for a while now and I thought it just needed to be adjusted. I took a good look at it this weekend and noticed that the tabs on the actuating arms are cracked (see photo). Took this photo from the passenger side with the sunroof in the vent position.
Has anyone seen this before? Any idea what could cause these to crack like this?
Thanks,
Mike
Thanks,
Mike
on
Thanks for the replies...
The parts are not available individually - you have to but the entire frame (cassette) which runs about $1500 or so. The parts themselves are made of Polyoxymethylene (POM) which is very difficult to bond making a repair iffy at best.
It's a California car and has never seen freezing temps. The mechanism itself works great and has never given me any trouble. It's just that freaking noise that's driving me crazy!
Mike
Mike
Is this in the front or the back of the glass? I havent seen a stress crack like this before but I believe it was probably caused from binding or lack of lubrication and possibly debris on the tracks. I have seen stress cracks in other areas and that is what usually causes the issues. If you do decide to purchase a new or used cassette and you are in southern california, I can install it for about half of dealer cost. Send me a PM if interested. Good luck!
on
It's in the rear - these are the arms that extend to lift the rear of the glass when it first opens. You can't see it in the pic, but there's also a tab on the inside that holds the glass down when closed. Since it's cracked, it's not holding the glass tight enough, allowing it to move and make noise.
Thanks,
Mike
Thanks,
Mike
cub4bearindiana
06-30-2016 06:11 AM
