Revs shoots up when pushed to the floor.
So, I've had my MINI for quite some time (Pushing just over 160k :p) and have never had any problems out of it. Until recently... I noticed whenever I press the accelerator to the floor, or even just past about halfway, my revs instantly shoot up about a thousand or so then gradually reside to the normal value, no matter which gear I'm in.
I'm assuming it's something to do with the clutch, but I'm not exactly sure which part it would be. If it's a certain part, then I have a friend who could help me replace it. Any help would be greatly appreciated!
Sounds like the clutch is worn out. Is your car an S or non-S?
If a non-S you may just be able to get a new clutch and resurface the flywheel:
http://www.waymotorworks.com/valeo-clutch.html
If an S you will probably need a new clutch and flywheel. The dual mass flywheel cannot be resurfaced.
http://www.waymotorworks.com/stock-c...-cooper-s.html
http://www.waymotorworks.com/stock-d...-cooper-s.html
Navigation & Audio Installing the PAC SWI-RC Steering Wheel Control Interface
Filmy
06-28-2016 08:58 AM
09-03-2015 03:01 PM
