Spark plug blow out #3 and now Dreaded P0303 code need help. MSD coil
Yes I have read numerous posting on this but I figured I will tell my story and maybe someone else had this happen.
I had the dreaded spark plug blow out in cylinder #3. I ended up having to put a new insert in as the threads were gone. When I tapped it out, I added grease to to tap and I would go a few turns back it out clean it off and re-grease it. I vacuumed out all the shavings which was very little from what I was able to see on top of the piston. I then put it back together and things were great for 3 days.
Today I got the P0303 code. I have a MSD coil and Magnacor wires. I just installed brand new NGK 4285 (BKR7EQUP) plugs. I had my scanguage clear the codes and restarted the car. You can feel the low rpm hesitation, but as you rev it it goes away. I know the check engine light will come on again.
So I am thinking of trying a new coil tomorrow, as I moved plugs and wires around with no luck.
Anybody got any other suggestions? I don't have a compression gauge to check the cylinder and I don't want to pull the valve cover unless I really have too.
I believe you are right slinger...
If this is a 1st Gen, check and make sure your plug is seated and then check your wires and pack. I just dropped a screaming demon on mine and have noticed a difference (new pack made a huge difference over a pack with 98000 miles on it).
How old is your coil pack? How old are the wires?
Yes this is gen1 Sorry I posted in wrong area. I installed the MSD coil 24k miles 1 1/2 year ago with wires at same time. I just installed new plugs (4285 BKR7EQUP) 100 miles ago.
I am going to see if I can borrow a compression tester later today. I don't have another coil, but I will be picking one up later today also.
