coolant leak MCS 2007
First is Mini collant really blue, have few spots and thought it was the windsheild washer liquid. Dealer indicated coolant , and the top suspect is the thermostat as they indicated these are a problem on 1st gen R52 mini's. My MCS is a 2007 convertible which was first gen. Dealship is $500, do they have to take the Turbo off or something?
Also, anyone seen a Factory Service Manual for a R52?
Coolant spots are blue. Thermostat housing/gasket would be highly suspect. $500 is high. If out of warranty, take the car to a local shop that works on Minis. Look around the thermostat housing for pooled liquid or dried white residue from the coolant evaporating to detemine if housing gasket is actually leaking. Could be the plastic coolant tank leaking at the seam. Make sure to keep coolant level topped off until leak is fixed.
If you, or you and a friend have any mechanical ability and a few basic metric tools, you can do the job in a few hours. If you'll do a search on "replace thermostat" in the "How To" section, it's spelled out step-by-step. Suggest you replace both the stat and the housing while in there. Order the parts on-line from Way and do it...You'll save $$$ and bond more with your MINI!
Kimolaoha
07-05-2023 01:04 PM
