Thermostat Replacement "HOW TO"???
I usually use google to find posts on here, for some reason the forum search is not too good. This is the one I used a couple of weeks ago:
https://www.northamericanmotoring.co...at-change.html
Pease keep reading that thread for at least 2 pages, there's some useful tips in there, so you won't have to take the ecu out for example.
Hopefully this helps a bit: http://www.pelicanparts.com/techarti...eplacement.htm
888.280.7799 | 6am - 5pm PST
It's quite simple. I used pelicanparts writeup.
-Remove the air box completely
-Remove Map sensor/bracket
-Remove 3 bolts on Theromostat housing
-Replace Thermostat/gasket
-Reassemble
I just did this recently, only problem I ran into was rusted Map sensor screws which needed to be drilled out
-Reassemble
PSIChocolate
08-13-2015 12:46 PM
