Trying to decide what to do to Cooper and in what order?
So the local club has a quarterly DIY day where techs will walk you through repairs and various procedures. I am trying to sort out what I should do next. Cooper is a 2005 S R53. He has 69 some odd k. So far I have replaced the thermostat and crank shaft pulley. I have recently changed the front pads and rotors, flushed the coolant and brake fluid and clanged the oil. So I'm wondering a) what to do next and b) what to do at the some time due to part placement, etc. So far what I have on my radar is:
Oil Pan Gasket (leaking)
Back Brakes and rotors (Overdue)
Power Steering Hoses (leaking)
Paint Calipers ()
LCABs (Ball Joints at this time?) One is starting to wear
Serpentine Belt? (at time of oil pan gasket)
VBelt? (Since this should normally be done at time of inspection II)
Air Filters
Struts (when?) (how can I tell if my towers are mushroomed?)
Fuel filter
Sway bar (I've heard this is a must?)
Anything else I've overlooked?
Paint Calipers ()
Air Filters
Fuel filter
Take care of the brakes and power steering hose leak 1st.
There is only 1 belt, the serp belt.
Look on top of the strut mount and it will be pretty obvious.
This is one of the 1st mods that should be done.
Do a search on some of these things and you will see lots of threads to all your questions. If not we are here for you.
Drivetrain RaceChip Ultimate install + review for b46
F55MidnightBlackCooperS
07-06-2016 03:13 PM
08-11-2015 09:01 AM
