check engine light, C342D, C3064
Woo Hoo the mini is broken again. Just had the valve cover replaced along with the timing chain and related components about a month ago 2200$ thank you mini.
now i have misfire codes, O2 code, transmission codes and unknowns looking for help with the unknowns ALLDATA is as normal NODATA.
codes are C342D,C3064, and the two trans codes P1777 and P1776 I think trans codes are related to it going in to limp mode.
truedrew
R60/R61 Stock Problems/Issues
08-10-2015 10:39 AM
