Water pump leaks - how many miles?
Old 03-12-2014, 11:27 PM
GalacticaActual's Avatar
GalacticaActual
GalacticaActual is offline
Eh, mine went at 81k DIY replacement was cheap, a minor PITA but overall not too bad.
  #77
Old 03-17-2014, 07:26 PM
RadioFlyer's Avatar
RadioFlyer
RadioFlyer is offline
Just keeps getting worse. Water pump last week, today I get a power steering failure warning. Tired of this now...
  #78
Old 03-24-2014, 08:16 PM
Amieko's Avatar
Amieko
Amieko is offline
08 justa 57k mi
During my inspection II at mini I was told my water pump was leaking and needed to change the serpentine belt. Quoted me $800 for both items. Bringing it to a friend who used to be a mechanic for BMW and quoted me $500 after he confirmed I needed to replace those two things.
  #79
Old 03-25-2014, 02:20 PM
STS-1's Avatar
STS-1
STS-1 is offline
I noticed a small puddle under my '09 Clubman S (73k miles)yesterday. It was under the driver's side, leaking down from the top of the gearbox. About 3 ounces or so, after a 10 mile trip. Another ounce or so today after a short trip in town. The expansion tank is empty when cold but wet. Car is running as normal. Looks like I will have to pull up the tutorial and get to work.
EDIT: Ugh, my headcold is making my thinking fuzzy. I called my MINI specialist and he says it's sure to be the t-sta housing based on the leak pattern. $115 for an OEM housing. So on Friday I'll replace it. I will try to document and post an update in case it helps. More is better IMO when it comes to DIY repairs.
  #80
Old 03-25-2014, 09:18 PM
Systemlord's Avatar
Systemlord
Systemlord is offline
I wish Mini would manufacture an aluminum version of the thermostat housing, they already updated the main water pump to aluminum. Did you know BMW has been using plastic thermostat housings/main pumps on BMW's for more than a decade?
  #81
Old 04-07-2014, 06:11 PM
STS-1's Avatar
STS-1
STS-1 is offline
So the good news is, thanks to the tutorial here on NAM, I replaced my t-stat housing last week for about $165.00 parts & coolant.
The bad news is that today, about 500 miles after the repair, I went to the dealer for a routine service interval and they found a water pump leak. So I guess I will be back in there shortly.
EDIT: Pump wasn't leaking. there was some dried coolant on the pump and the sevrice advisore told me that any time they find that, they recommend replacement. I just left it alone and it has not lost any coolant, so false alarm.
Cereall
09-05-2019 06:05 PM
KrisMiss
01-03-2016 02:02 PM
danielbrookes_9
10-03-2015 12:51 PM
gmonde
09-08-2015 06:37 AM
Lex2008
08-16-2015 08:33 PM
Quick Reply: Water pump leaks - how many miles?
