Boot won't open. Tried cleaning connections. What's next?
My boot won't open. It releases fine with the cable under the back seat. I removed the handle and sprayed all the connections with contact cleaner. It still isn't working.
Is there anything else to try before I replace the whole handle?
If I do end up having to replace it, where's the cheapest place to buy one?
The only thing I hear when I toggle the lock switch or key is the the doors unlock. Nothing near the boot. I suspect the handle because in searching around the forums the only issues I ran into were people with corroded handle switches. I took mine off and there was some corrosion on that metal clip. What else should I check?
I'm missing a license plate bulb lens but it's been several days and I took it apart last night and nothing seemed wet anymore so I don't know if its coming back from the dead.
No, Interior lights still work. As far as I can tell I haven't lost anything other than the boot opening.
Wow if the lights still work then is not the fuse, did you test the fuse at all? I had the same problem but the first time was due to water in the connector and it would open by itself I the open the boot handle and put a blow dryer to dry the connectors and that worked until I washed the car, after that my interior lights and boot fuse kept blowing, I replaced about 10 fuses before it started to work as if nothing was going on. I'm going to tackle the boot handle and try to water proof it before it does it again.I hope that you don't have to change anything and can solve it, it is very annoying when you have to open it from inside.
It could be the door handle, they tend to get water past the gasket, if you can get it working replacing the gasket is a must and the lens , two of them on the bottom of this post.
http://www.ecstuning.com/Search/ES92095/
Handle in chrome, we have them in primed version also.
http://www.ecstuning.com/ES78095/
The lens pop out over time due to age and then water gets in there and corrodes.
http://www.ecstuning.com/Search/ES92096/ES92096
Good luck, trouble shooting electrical can take some time.
Lol this is just too funny, they way this cars behave is is frustrating I took mine to the car wash last night with my fingers crossed and thank God nothing happened, everything is working. Next thing to do is to buy the gasket from ECS I went to Manhattan MINI this morning and is 20.00 but they don't have it in stock, I also need one of the horns and that it 70.00 !!!!!!! Crazy!!!! I'll be ordering from ECS and save a bit of money.
Also I think that they have the hole handle that includes the switch and the lenses for about 80.00 or so, good luck I hope it helps
Yes the handles come with the lens , two of them , the internal switch and the gasket on the back.
This is the chrome one.
You can see more shots of the product to solve your issues.
If you need the primed version ( for painted handles ) or just plain flat black we have those also.
I would upgrade the lighting and pop out the old bulbs and go with LEDs while your at it. Great upgrade while your have the handle out.
http://www.ecstuning.com/ES2598621/
Let me know if you guys need anything else.
** And you can click links to go to the products and check them out ! **
No flicker, they contain the built in resistors.
Currently have them running on our MINIs and they look great. One of the best outside lighting upgrades.
I don't think that you can, as far as I know the handle comes with the lights and the Micro switch but I could be wrong
Give this part a try at the dealer maybe they have it. Part number 51477114536 MICRO SWITCH, TRUNK LID KEY BUTTON 0.01 1 $47.64
or this http://www.ecstuning.com/Mini-2005-C...h/51477114536/
Im not 100% sure if this is the part
good luck
good luck
You can get the little micro switch but you have to take apart the handle to install it and its a little intensive to install without breaking other things. Then hoping that nothing else is corroded because it installs on a little board. Also if you are leaking from the lower rubber seal ( part of the grip ) its part of the main handle and not available on its own
Do you hear anything when you press the handle button? If you hear nothing, it is probably the switch or wiring in the handle. If you hear the latch mechanism trying to unlock, the handle is working and the problem is the latch.
