Query - R53 Oil Pan Gasket (quick change)
on
Hey R53'ers!
May you lent me your collective knowledge by answering some short queries?
1 - Is the MINI SST belt tensioner is required for oil pan gasket replacement?
2 - Can the oil pan gasket be replaced without removing the condensor and disconnecting the A/C lines?
3 - How high must the car by hoisted up?
The the serpentine belt, supercharger, pulley, damper, and A/C compressor have all been replaced.
Yet now the car is leaking oil.
This very thorough write up appears much more time consuming and may include procedures that can be omitted with some shade tree jimmy rigging.
Suggestions?
Thank you in advance!
Suggestions?
Are you positive it's the pan gasket? The Crank Position Sensor (CPS) o-ring is another culprit in mysterious oil leaks. It's in the front of the engine near the middle.
https://www.northamericanmotoring.co...on-sensor.html
Did the R&R on both mine and a friend's and it cured the mystery ooze on the engine.
on
on
Off-Topic : BTW, my heart goes out to your community for the recent killings of two of Santa Cruz's finest. I attended UCSC, lived all over towne for 6 years until 2004, was even married there, and still have some life long friends on your side of the hill. So when such violence happens there, especially from transplants, it both angers and saddens me.
![Frown](https://www.northamericanmotoring.com/forums/images/smilies/frown.gif)
My original post:
Just replaced the CPS o-ring today. Used the under engine ratchet strap method (remove lower engine mount, replace bolt, use ratchet strap to pull engine back a couple of inches.) Worked pretty well, but couldn't for the life of me get the connector off the CPS. After attempting that for 30 minutes decided just to take the CPS off (10mm bolt) with the connector attached. Couldn't see the bolt through the filth, but could feel it. Even after getting the CPS out of the block, I couldn't get the connector off. Still was able to replace the o-ring and reinstall with the sensor attached.
Getting the bolt back in was a bit challenging, as I was working blind, but after finger tightening and working to tighten it with a variation of a long socket, then a standard socket with a short extension was able to snug it up.
That pretty much says it all. I recently replaced my AC compressor, so I'm getting used to being under there. More than a 10 minute job (someone else said that) but more arduous than difficult, just working mostly blind.
pic gives you an idea where it is.
http://www.realoem.com/bmw/showparts...82&hg=11&fg=10
I put it on ramps, remove the splash pan, and I removed the PS fan, though others have said there's enough room not to. You can gain a little room to work with the connected CPS by removing the wire from the clips it is in.
If you need any clarification, feel free to email (my username at yahoo) and I can talk you through it.
OT: Yeah, I grew up here, and we seem to have more than our share of nut jobs that show up.
on
For strap method, pull the lower motor mount (two big bolts, one horizontal, one vertical.) I can never get the mount out without removing the bracket on the engine, but others don't seem to have that problem. Insert bolt back into engine bracket and run strap over the front crossmember and through the engine side motor mount bolt. You may also need to remove the PS fan (two bolts.) Then cinch it up and go to it.
Etrain
14
08-20-2015 10:32 AM
Etrain
11
08-20-2015 10:22 AM
Lex2008
08-16-2015 08:33 PM
minipopkart
08-13-2015 05:22 AM
