P2FD7 Fault Code
on
P2FD7 Fault Code
Hi all,
I have been experiencing random boost loss with no visible error codes on my scangauge. I am running the alta stage 3 tune which usually peaks between 19-20 psi depending on rpm, gear, temp etc. At random times I'm only getting 12-14 pounds of boost. Like I said, nothing is causing a OBD code to be thrown. Today I plugged in the accessport to look at various parameters and checked the diagnostics there just to see if there was something the scangauge wouldn't read and sure enough it said ECU P2FD7. I have searched and couldn't find what this code meant. I reset it and that didn't seem to help. Can anyone help with reading that code or help to diagnose my boost problem? I plan to check the diverter valve in the morning. Any and all help is greatly appreciated. Thanks in advance! - Hilton
on
I checked the diverter valve last weekend and the diaphragm is fine. Tore the car down today and checked all boost tubes and vacuum lines and found nothing. I'm still interested if someone has any info on the code in my previous post?
Also, has anyone had any problems with the vacuum solenoid? Could that be the problem?
Steffen.Johnson
71
01-26-2021 09:11 AM
ShadyCoop
09-20-2015 08:57 AM
sirfrank
09-11-2015 01:36 PM
