window problems 2009 cooper clubman
I have a 2009 mimi clubman and i am having trouble with the right side window. it is not closing right. it goes up but somtimes will come back down and stop. and it is not sitting correctly against the 3rd door. someone said the computer need to be reset.. any help..
You can try this:
Instructions
Instructions
- 1 Insert the keys and turn on the ignition. It does not matter whether you start it or not.
- 2 Put the window all the way up (if you are able).
- 3 Press and hold the window switch in the up position for 10 or more seconds. Do this with the door closed.
- 4 Open the door to make sure the window drops as it should. Close the door to make sure it goes back up again.
You can try this:
Instructions
Instructions
truedrew
R60/R61 Stock Problems/Issues
08-10-2015 10:39 AM
PelicanParts.com
08-04-2015 02:45 PM
