HALP! :) Retrofitted fog lights, get nothing when I turn the key
Ok, so I went slowly/carefully through the install for the retrofit kit for fog lights.
A pain in the rear, but it is installed. Now I went to start the car, and nothing. Everything else works, gauges/etc. Everything except it won't try to start.
I've checked and rechecked where I was messing around. Cleaned connections to battery, and to fuse box. Relays/fuses look fine.
Any ideas!??!?!
Any ideas!??!?!
OEM directions call for tapping power from the fuse box in the engine. Make sure the connection there is solid. Also, if you removed the BCM connector to tap into the high beam circuit, make sure that's solid as well.
edit: could be the clutch safety switch - that's one item that would fit the scenario
Great to hear you got it fixed. ![Thumbs Up](https://www.northamericanmotoring.com/forums/images/smilies/thumb-up.gif)
Here are the instructions:
https://www.northamericanmotoring.co...t_Retrofit.pdf
#5 on page 4 easy to miss.
What year is your MINI?
![](https://www.northamericanmotoring.com/forums/signaturepics/sigpic130940_6.gif)
Yes, I knew some people were trying to fit this to pre 2004 , according to the ETK and MINI it 7/2004- . But have not seen it done. You were the first to do this ?
That's great news
That's great news
Great that you go this to work.
You are talking about the toggle bank pack for the green light:
![](http://c1552172.r72.cf0.rackcdn.com/334143_x600.jpg)
Might need coding for that to work.
07-16-2020 12:54 PM
12-23-2015 10:36 AM
