Key fob or serious issue?
I recently bought a 2007 Mini used with 62k miles on it. Everything seemed fine except the key.
I'm 'lucky' enough to have one of the keyless-but-not-really remote keys.
Originally the fob just wouldn't eject from the slot with out some serious jiggling and pushing. Then it wouldn't eject at all, or would eject but leave the car still running. Eventually i just resorted to pulling the key out and turning it off with the button.
Now it's decided to give me a wondrous new problem where putting the key in does nothing at all. i can jiggle it, push it, anything, but it will not light up my dash or turn on the radio.
It's not the battery in the car, because i can manually turn on the radio and such, and it's not the key battery because i can still unlock/lock my car and pop the trunk.
The only fix I've managed to find for this is holding down the button for about 20 seconds until the car just turns on by itself; which is problematic because the key doesn't even need to be in the slot for it to turn on.
Is this a problem anyone else is having or has had? and is there an easier fix than replacing the whole slot?
What are you expecting the key fob to do? If the start/stop button works then the fob is being recognized by the car. Do you have comfort access (little black button on the door exterior door handle)? If so the fob doesn't have to be in the holder at all and the holder doesn't do anything. The fob just has to be in the car, step on the clutch (or brake if its an auto box) and hold the start button.
Your first post has me confused. When you shut the car off are you hitting the 'start' (off) button first or pulling the fob out while the engine is running?
Your description is spot on for a failure to the Start/Stop switch. But hey, what do I know...
If your concerned @ difficulty of replacement, I can assure you it will be one of the easiest installs you've every performed and if you want I can PM you instructions on how to remove and replace it.
When I put my fob in the slot mine doesn't do anything until I hit the start button. I think inserting the fob is akin to putting a standard key in a slot but not turning the key.
& i hit the button then take the key out then hit the button again.
What im worried about is the fact that my car can be turned on by anyone just by holding the start button for 30 seconds with or without key
You can either take my (and other members that have chimed in) advice, or you can continue to try and convince yourself that your problem is bigger then it really is, honestly Its up to you.
Yeah everything I've looked at says its supposed to, wish i had that comfort access, my key is no better than a regular key
speedbird_1
08-15-2015 04:44 PM
truedrew
R60/R61 Stock Problems/Issues
08-10-2015 10:39 AM
