Do the common problems continue to re-occur??
Other than the timing chain and carbon issues, when you have the smaller issues (i.e. water pump, vacuum pump, thermostat, oil leaks). Are these just one time problems or are they constantly re-appearing? I ask this because I'm seriously looking at a 07 that has had all these things and they have all been repaired my the mini dealers and I wonder if they will continually re-appear if I were to buy it.
High pressure fuel pump was also updated when replaced...kinda of an $$$ part.
Many other parts were re-engineered, like the valve cover/PCV system....many of the changes were implemented on a rolling basis, but 09+ is pretty safe
That having been said, the 07's are kinda cheap cause folks often stay away. Just depends on your level of risk tolerance!
PelicanParts.com
08-04-2015 02:45 PM
