How do I remove the water tube?
#76
Yea, That smoke if you reeving the engine and then putting it into drive possibly on the transmission. I would stop doing that all together till you figure out was going on . The Oil leak at the front would be easily seen need the turbo.
You need to dig into that shiftier section.
For the oil line and oil filter housing leak.
https://www.northamericanmotoring.co...leak-pics.html
#77
Welcome.
The engine will serge down hair when you switch from neutral to drive, and you will feel the engine move a bit and from drive to reverse. How much it is moving, thats the question.. A lower engine mount that is bad can cause the engine to move around in the engine bay more.
https://www.northamericanmotoring.co...ference-2.html
#78
After replacing the thermostat housing i got the same p0706 code, did the engine mount fix your problem?
#79
This is just plain wrong, at least with respect to my 2009 Cooper S:
One of the tabs closer to the end also got caught on some wiring. It was easy to move the wiring out of the way once I could find it between openings in the intake manifold.
#80
Obviously you don't like being contradicted by your elders, but:
So, obviously, on some Minis, there are wires attached to one of the tabs.
I posted a similar note last night, and I see that it was deleted.
I shop at ECS Tuning. If you're trying to convince me not to shop there anymore, have this one deleted.
ltjpunk7
09-06-2015 07:32 AM
patsum
08-26-2015 06:29 AM
Getrieben
08-15-2015 09:09 PM
