OEM Turbo Inlet Pipe Crack / Rip
I have a 2009 MCS Convertible and while I was making a few adjustments to my CAI I had noticed that the turbo inlet pipe, down by the hose clamp on the turbo, had ripped? I am most likely going to have it replaced by the dealer but was curious if this has happened to people before?
Check for oil contamination in the inlet line. If there is anything more than a little engine oil residue, that's probably abnormal. Check out the photos I posted here:
http://www.mini2.com/forum/mini-coop...urbo-seal.html
That's pretty much all you should be seeing.
While you've got the piping off, check the compressor fins and see if they're covered in oil. A little bit is normal, however if they are black and coked up you've got a problem.
As an aside, does anyone know if the intercoolers on these cars have a drain plug?
The oil mist vents directly into the intake piping, passes from the compressor side of the turbo through the intercooler and, since the oil is hot and the intercooler cold, it condenses on the inside of the charge air cooler.
Over time it can build up in there and reduce it's efficiency.
blackie
10-02-2015 07:41 PM
08-19-2015 12:51 PM
