Whining noise after 15% pulley install? (not as nooby as it sounds)
Hi folks,
Just did a bunch of work on my 2003 R53. Powerflex control arm bushings, new radiator, supercharger oil, JCW plugs, new wires, belt, 15% pulley, axel boot, top hats, tranny fluid, probably a bunch of little things I'm forgetting. My AC has been failing for a few months now. You can feel the compressor turn on and off when you're driving, roaring when AC is on, trouble taking off with AC on, but it's still cold, woo! (as long as the compressor is on)
After doing all of this maintenance on my car, I noticed that when I'm accelerating from a stop, there is a mosquito whine as I'm taking off, up until about 3rd gear. It gets higher as the engine works. It's not a SC whine, my other MINI has a 15% installed and it doesn't make that noise.
The other day I was idling in traffic with my AC on and smoke started coming out of my hood. My temp gauge was right in the middle and it didn't smell hot. Turned off AC and smoke stopped after a second. I parked and pushed my car back and there were leaks on the ground. Touched them and they were oil but not motor oil, much thinner and yellow-ish.
Assuming this is what AC compressor oil looks like and my compressor just went kaput???
Also would this whine noise I'm hearing while accelerating have to do with a failing compressor even though my AC wasn't running? The noise is constant, AC or not.
Please help a girl out! Thanks!!
Sara
Sara
A few suggestion before you tear into anything....
Check your powersteering fluid level....while the color does not match (compared to new) the lines can leak, and the pumps can whine, especially when low on fluid. Next, look, try to see where the oil is comming from....
If the ac started to leak "oil" that is uses for lube, it is circulated with r134a gas at very high pressure...a sudden leak means that a cloud will usually form momentarily, and the ac will stop working....it is much more common gor the leak to slowly reduce the psi of the gas, till the sysrem cannot be turned on....
The A/C compressor does have a clutch on it....it can fail, leaving the compressor on/off at all times.....Does it still work?
Did everything get cleaned up from the prior leak?
I'm wondering if a few drops of oil from your PS leak blew back and hit something hot...like the PS motor, exhaust pipes, etc..
Both cars are S's from your signature....
I'm going to suggest you try to locate where the whine is....a mechanics stetchope, or even a stick, touching some parts and your ear (carefully, think about the size of a broomstick) at the same time can help determine WHICH item the sound is coming from....so you can determine if the sound is coming from the AC compressor, alternator, or even the SC (if the PTO is low on oil). The sudden burst of smoke is interesting thing to go with the noise IMO.
squawSkiBum
10-02-2015 09:21 AM
iamcamkeenan
08-10-2015 03:31 PM
