Code P1611, and P1692
I am guessing you have a CVT transmission? How old is your battery?
P1611 Serial Communicating Link Transmission Control Module.
This can be do to several things, one being a bad battery or cable is corroded.
P1692 is considered a safety level code.
Electronic Throttle Control Monitor Level 2/3 Motorized Throttle Control and Fuel Injection Switch Off 'A'
It can be set due to an internal calculation error in the ECM, (engine speed, (limit) etc).
The fuel injector cut-off would be ECM controlled. Meaning it deactivated an injector due to a fault, malfunction in engine speed limitation or engine speed control, fault in electronic throttle module.
Battery is new, and good. I checked a lot of connections, no corrosion. Car ran good for about 5 min, and now thinking the transmission control module is bad. I first thought it was the transmission computer, but that didn't help.
Anybody know if the transmission control module needs flashed, or programed for my car?
I'd love to take it to the dealership, but got lots of stuff going on right now, and too many bills. I know where the transmission control module is after ripping everything in my car apart. Found it under the steering column.
Steffen.Johnson
71
01-26-2021 09:11 AM
