Is their a recall on the wiring?
My 2003 mini cooper has wiring issues. I found 5-6 wires shorting out messing up radio reception, fixed that, power steering fan received no power, had to rerun wires for that, and now transmission is acting up. Replaced transmission computer, and got a main computer. Main computer wasn't flashed, but without the car starting you can move the shifter to see what gear you are in, and it said P all the time which is the issue so neither computer fixed the issues.
That is a video to help show what I mean by issues I am having.
Nope...
A few folks have fried wiring harnesses from doing things like adding driving lights without a relay to handle the ampage....
on a 10 year old car, if it has been exposed to salt/mag-chloride decicer, wiring problems do happen...
have you found why in the bad wiring the wire failed? Kink, bend, chafe, or perhaps corrosion from a spot a person probed with a volt- meter when doing prior work (a terrible practice some folks use)?
Nope...
Power steering fan I am not sure what was up with that.
Navigation & Audio HK Replacement With New Components
Filmy
15
06-06-2023 06:27 AM
