Automatic Transmission Issue
My 06 S has nearly 100k on it.
One of the first things I did was to start adding fresh type IV ATF to the transmission (after draining of course).
Problem is that the 2nd to 3rd shift was a bit abrupt and after the first fluid change (about 2 qts) it seemed like shifts were getting smoother.
However, after adding Redline ATF the 2nd to 3rd shift was smoother but now seems to slip a bit under load.
This is all happening when the car is at operating temperature.
I'm wondering if I should prepare myself for a new trans???
Are either of those the equivalent of the required JWS3309. Did you follow the flush fill procedures?
It's not like filling a crankcase. Trans fluid needs to be warmed up before filling and running through the gears is necessary during filling procedures....There are 3 plugs for the fluids, a fill, an overflow and drain plug. Overflow is used for fill reference.
It does sound like your valve body is the problem..just as stated above... I would highly recommend changing your fluid with a synthetic ATF.. That really is key to have these type of transmissions last.. Factory fluid they use is nothing fancy and it is not at all a synthetic.. good luck!!!
Alrighty, here's an update to this thread.
Changed out the valve body sourced from RevMax.
Shifting is MUCH better and so are the downshifts.
But one weird thing is that when cold, the 3-4th shifts holds past 3k when under a bit of load.
Any ideas?
Also, should I reflash the transmission ECU? Not sure why but I think I've read this somewhere.
Any ideas?
So it's not necessary to reflash the ECU?
09R56
11-16-2022 10:49 AM
lalroma
20
04-02-2022 06:19 PM
08-19-2015 12:51 PM
08-19-2015 08:27 AM
