Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Clubman (R55), Cooper and Cooper S(R56), and Cabrio (R57).
I'm about to do some carbon cleaning this holiday weekend, and I won't have anyone around to help me bump the engine with the starter. Can I advance the engine by hand? Thanks in advance for the prompt responses
You access it through the right front wheel well. I don't know offhand what size the bolt is, but if you have a metric socket set, you'll have a socket that fits.
Hey folks, just now getting around to doing this, and I have a question: Is it ok to turn the crank pulley either direction? I would imaging that Counter Clockwise is the correct direction. working on it right now, can someone please respond?
Day late & a dollar short --- just now saw this thread! Bentley manual indicates CW, not CCW.
is it ok to slight wiggle the crankcase bolt counter-clockwise back and forth (just a little bit)? I'm doing a piston soak and would like to ensure more cleaner gets doing into the rings, but I don't want to mess up the timing. I've seen people do this in some videos before, but not on a MINI
You're right - not worth the risk. Yep I meant with the plugs out
Rather that turning the engine backwards slowly turn it -- by hand with the plugs out -- in its normal direction of rotation 180 to 360 degrees. This will have the pistons going down then up again. Not as "good" perhaps as "wiggling" the crank but better than nothing.
