Engine oil for high mileage and high ambient heat
on
Good day all,
Normally I have been running 5W-30 before I moved away from the moderate climate of Seattle. My car is a R53 JCW with a 17% pulley. But now I live in Reno, NV... an area with daily highs of 95+ degrees during the summer and daily lows of 0 degrees in the winter.
I believe I will change my oil again before winter, so let's not focus on the winter. Let's talk about summer oil. It gets hot everyday, I drive during these times, and my car just hit 100k miles. I have been using Royal Purple and change my oil every 5-6k miles or so.
I need to change my oil here soon so I was wondering if any of you would recommend switching from 5W-30 to something thicker (because of the heat) like 5W-40. Please let me know what you would do!
Thanks,
Ryan
Thanks,
Ryan
In a full syenthic you will (hopefully) not find many 10w-40 oils....this weight is for older engines with wider tolerances.... I would NOT use a 10w oil in a mini....the builders specify a 5w or 0w and a 40 or 30....mix and match...but the oil galleries and bearings are all SIZED FOR those weights....
on
I don't think any harm will come from it, but I don't think Mini recommends any 0W oils in the 1st gen cars - my R53 manual says only 5W-30 or 5W-40 for "all climates". I personally wouldn't use a non-recommended lower viscosity - you're more likely to do harm than good. I'd use either of these year-round, or if you want to try and refine things a bit, the 5W-30 in the winter and the 5W-40 in the summer.
I guess I'm saying you're probably overthinking this.
- Mark
- Mark
on
I've heard this before, 10psi oil pressure per 1000 rpm at normal operating temperature.
-A couple months ago I was asking myself if royal purple, mobile one, or castrol would be best, and what weight. I came across this tech article which explains in great detail this "rule of thumb" that dad had told me long ago.
You might enjoy this:
http://new.minimania.com/article/289..._Misunderstood
on
07-16-2020 12:54 PM
M7Speed
08-06-2015 01:48 PM
