Crank sensor o-ring replacement
I was under there about 3 weeks ago for an oil leak. It was the seal on the oil filter tho.. broke free about 4500 miles after previous oil change. Must have hit a real good bump?! No oil leaks anywhere else, its real clean down there. Swapped my SC at 92k miles and that's when I cleaned all previous gunk left unattended by PO. Nothing was new and it wasn't even that bad. I do not lose oil between changes and its always very clean when I changed it. I'm very thankful for this !!!
I agree that it probably is everyone has or has had that leak. And it is easy to fix.
BUT you should consider an upgrade to the balancer while you are there. Those all eventually go too and the ATI Balancer is much better than OEM. Occasionally ATI sells some blemished units as a significant discount. Just cosmetic problems and when I got mine, I couldn’t even find it as it looked perfect to me.
///Rich
///Rich
should be 12147514983 Look it up on realoem, then plug the part number into the pelicanparts search box.
#9 here: http://www.realoem.com/bmw/showparts...82&hg=11&fg=10
pelican link: http://www.pelicanparts.com/cgi-bin/...FILTER_928M=ON
Unless you are ordering extra stuff from a vendor, that's probably something to get from your local dealer so you don't pay shipping. $4.
Drivetrain Help on MAF Sensor Clip - Cannot Remove
Motown
04-20-2018 09:31 AM
squawSkiBum
10-02-2015 09:21 AM
JPMontes3
08-23-2015 01:26 AM
PSIChocolate
08-13-2015 12:46 PM
