P1237 Help
P1237 Help
Hey I've been getting this code the last few weeks and it is confusing me. It says "secondary upstream manifold air pressure sensor low" the code will go away and then come back for no apparent reason. I've read some threads about it and they mentioned checking the bpv for possible broken spring. I reached in and the spring seems fine. It is stuff and springs back the way I would expect it to.
I'm at a loss could it possibly be a bad tmap sensor? Looking for any help or advice. Also this is the only code that is popping up.
So I pulled the intercooler and inspected the boots. My apologies for no pictures but everything looked good to go. There was a bit of an oily build up inside the boots and a little in the intercooler. I also inspected all the lines to look for anything disconnected or loose and did not find anything.
On one side I guess finding nothing out of the ordinary is good but on the other still unsure what could be causing the code. I have not gone through a full drive cycle yet so maybe just moving things around a bit was enough.
Any other ideas what could cause the P1237 code?
Thanks I will give that a shot next looks like.
Today the light went off again... While it was off I was in 2nd around 2500 rpm and I blipped the gas and quickly brought the rpms up to 3400 or so. The light came on right after I did that. This is not the first time I was able to replicate this. I am just wanting to lay out everything I've experienced in case some one comes across this same issue later.
So I never did end up changing out the sensor. I did unplug it and inspect the wires for corrosion but there was none. I think that removing the intercooler and checking the connection point to the sensor scared the code away because I have not seen it since the last I had updated this. Sorry I can't be if more help.
update: I didn't replace the sensor either. I did however remove the intercooler and checked all the vacuum lines. The vacuum line connected to the bypass valve was 95% falling off. So loose that when I barely touched it, it did come off. I re-seated all the vacuum lines, zip-tied them, and the check engine lite is gone.
I think the JCW vacuum line T for the intake creates extra pressure forcing the vacuum lines off their connections.
Bumping this. I'm having the exact same problem as the OP. AWheatle, can you provide a photo of the vacuum line you're referring to? When I installed the Detroit Tuned BPV I didn't see any vac lines that went to it. Surprised me honestly since I figured the system needed vac to control the valve.
Also, does anyone know what the car should be reading for vac while at idle? I'm usually at around 18-19 in/HG.
fifty9singlecab
03-22-2012 09:28 AM
