Wheel speed sensor problem
So, recently I had my tire pressure light, DSC light, and ABS light come on. After doing some research, I found that the cause was likely a wheel speed sensor. I replaced both wheel speed sensors hoping to fix the problem. Now, however, all the lights are STILL on, in addition to the "service engine soon" and "BRAKE" light that comes on....the light that is typically associated with leaving your ebrake engaged. It seems as if my computer is really confused at this point. I drove the car to see if the lifts would go away, and I also tried disconnecting and reconnecting the battery...any ideas what my next move should be?
Thanks!
SooperCoopers
Thanks!
SooperCoopers
07-16-2020 12:54 PM
