Drain/Fill Trans Plug
Consider using an oil extraction pump. They can be found for $40-$60 at local marine supply stores or used in Craigslist. When the lower plug is in too tight the risk is rounding off the head or stripping the threads because there is a tight bond between the dissimilar pan metal and plug metal. Don't ask me how I know.
If the fill plug is in too tight first make sure you have the correct allen head inserted all of the way.
Then go to work with a longer handle.
Not many other options.
If you strip the hole you are still in the same boat of having to take it to someone.
Sounds like you have followed the JUST DON"T TAKE THE DRAIN PLUG OUT FIRST rule.
It is a rule to live by.
Navigation & Audio HK Replacement With New Components
Filmy
15
06-06-2023 06:27 AM
Sc00terbum
09-11-2015 07:17 AM
