Mysterious Ticking - Bad Crank Pulley?
Hey guys,
I'm new to the mini crowd (formally a ls1 guy) just wanted to get into something different, that got better mpg and handled better.
I used this forum a ton when deciding to buy a mini, so I figured this would be the first place to start with a problem.
I have a 2006 S 6 Speed, with 65k on it. Since I got it a couple weeks ago, it had a mysterious ticking noise that I noticed at idle.
Here's a video, I'm not sure if anyone could really hear the sound apart from the engine, but its like a rhythmic clicking.
Now if you guys think it is a crank pulley, is it better to stick with OEM, or is the ATI better? (I know us small block guys love their stuff)
I had an 04 with that same ticking noise.. In your video there is a round black cylinder type thing right above your yellow dipstick.. it has hard plastic lines running to it.. that piece which I cant remember anymore what it is called (think PVC valve) is what was making a very similar ticking noise as what I hear here.. easiest way to know is while its running try to put your hand on it...you will feel it pulsing.. see if that is what it is..lol..
on
When my chain guides failed they did the same thing. Noise at idle and low speeds. Get the rpm up around 2000 and it went away. Sounds like your on the right track there. If it is the chain guide and its broken in pieces replace the oil pump. Your right there anyway. Better to be safe than have to tear it all apart again.
Just fixed it!
The top bolt on my tensioner stop was missing and rattling around with the motor running.
I found a bolt in my garage that happened to fit, but was a tad long. Trimmed it down, and threaded it in. Took it for a drive,no more noise.
Thanks for your help guys, I'm glad it was an easy fix. :cheers:
patsum
26
05-29-2021 06:29 PM
larryd96
11
09-08-2015 05:01 AM
M7Speed
09-03-2015 07:48 AM
