Air conditioning clutch engaging intermittently
Today, on my second drive of the day using the air conditioning, the clutch started sporadically disengaging. The air would go from cold to lukewarm and humid, and the drain on engine power would be gone. Then, it would intermittently re-engage, and act as normal. Right now, with my car in the garage, if I turn the air conditioning on, I can see the compressor engage, and it stays engaged, blowing cold air. Any ideas what was causing this?
Prior to either compressor clutch or clutch coil failure, does either work intermittently or is it a sudden failure?
07-16-2020 12:54 PM
MiniDan
09-03-2015 04:05 PM
