Traction Control and TPS lights stuck on.
ya your going to have it checked...
this might not help you... but I had the BIFECTA lights (TPMS and DSC) dont confuse with the common trifecta (abs, tpms, dsc)
I had mine fixed today after an alignment... as these lights can come on due to bad steering angle sensor.... mine disappeared after I had the alignment done... so I lucked out on thiss coincidence.
there is also a write up somewhere where you can reset the DSC/TPMS where you pull the fuse out then back in.... I can't seem to find it though
07-16-2020 12:54 PM
truedrew
R60/R61 Stock Problems/Issues
08-10-2015 10:39 AM
